Jedan dobar tutorial
https://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=28http://www.sciroccoregister.co.uk/carforum/viewtopic.php?t=10710Preporučeni glavni cilindri
22MM gli
22MM scirocco
23mm audi
23.5mm audi
22mm Corrado (G60 w/o ABS.)
http://forums.vwvortex.com/showthread.php?5449123-22mm-master-cylinder-upgradeOriginali bi trebali biti
Boosted- 20.64mm bore
Non-Boosted- 17.46mm bore
http://forums.vwvortex.com/showthread.php?1849689Which brakes will you be using? A 22mm master cylinder is good as part of a big front brakes upgrade. But the master cylinder by itself is a downgrade if you keep the stock brakes. All that happens is you have to press the pedal harder to get the same braking action. You have to press about 15% harder to get the same brake force at the wheel (but the pedal does move 15% less). A larger master cylinder is exactly the same as a shorter lever, less movement, but more force required.
_________________
Projekti
Golf Mk1 83' 1.9TD -
http://golfmk1.info/viewtopic.php?f=8&t=132Golf Mk1 Cabrio 89' 1.8 8V DX / 2.0 16V ABF -
http://golfmk1.info/viewtopic.php?f=24&t=32
